Results 1 to 3 of 3
Thread: VW Passat Service
    VW Passat Service
    Hey guys,
    Just had a 150k service on my 2008 Passat R36, and they mentioned a few issues they'd identified. I just paid for the service, and decided to touch base here first to get some advice on the fixes they recommended first. Naturally, I want your advice on if it is something I should get done with VW themselves, or buy the parts online cheaper and have a local mechanic do the work. If you can suggest any parts, where to buy them and even pricing on the below, i'd be appreciative!
    1. FOUND SLIGHT OIL LEK FROM FILTER HOUSING, WILL REQUIRE NEW FILTER HOUSING - PARTS AND LABOUR $511.00
    2. INSPECT SUSPENSION-RATTLE FROM O/S/F AERA OF VEHICLE WHEN GOING OVER BUMPSCARRIED OUT INSPECTION OF VEHICLE
    FOUND O/S/F AND N/S/F ANTI ROLL BAR LINKAGES WORN AND WILL REQUIRE REPLACEMNT - PARTS AND LABOUR $332.00
    3. FOUND O/S/R SHOCK STARTING TO LEAK OIL AND WILL REQUIRE REPLACMENT
    4. RECOMEND REPLACING BOTH REAR SHOCKS - PARTS AND LABOUR $876.00
    5.
    FOUND REAR BRAKES HAVE APPROX 5000km REAMNINGWILL REQUIRE NEW BRAKE PADS AND DISCS PARTS AND LABOUR $617.00
    Any advice you can provide will be much appreciated.
    Thanks!
    Dec 2008
    Sydney/Canberra
    I won't go and second-guess another workshop's opinion or their pricing structure, but with the rear brakes, you'd want to at least get a European specialist to do them as the Electronic Park Brake needs to be manipulated with the diagnostic computer to replace the pads.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Any advice on brands, approx pricing (e.g. is the above just a rip-off or is it competitive), and any recommended people to do the work in Sydney area (Northern Beaches).
