Results 1 to 2 of 2
Thread: VW Passat B8 132 tsi owner
    Nov 2018
    Cairns
    My Passat empties coolant reservoir every 10000 klms. Has been to dealer 6 times to be checked pressure tested and refilled had thermostat housing water pump and coolant reservoir replaced as possible sources of leaks but the problem persists. VW now states coolant consumption of up to
    500ml per 1000 klms is within specification I find this ridiculous on a new allegedly high quality car. Any ideas
    Get the rain tray off and look up. If there’s coolant leaking you should see some tell-tale dried up pink crystals from wherever the leak is.
    Also check to see if there’s anything on the rain tray. If not give it a good clean before reinstalling so that anything new is obvious.
