i change a new dual clutch for my passat , in the first step of basic setting it show 4 0 0 but after starting which is the second step it show 255 17 0 when i check for the fault 17 means ( 1 clutch travel ramp grinding point out ) pleas can anybody tell me what is wrong
You should post this in the Passat forum Not the Newbies forum and put a more descriptive heading to it
Like Dual clutch fitting problems in 2008 Passat
