Results 1 to 5 of 5
Thread: Trailer Wiring
    Nov 2020
    Adeladie SA
    Trailer Wiring
    Hi All,
    First time poster so play nice
    I was intending on installing a third party trailer wiring module today, but once I go the LHS trim removed I found a plug and odd looking connector on the wheel well.
    Is this for OEM trailer module?
    Couldn't post a photo
    Thanks
    Phil
    Pacific Paradise QLD
    Quote Originally Posted by philt View Post
    Hi All,
    Thanks
    Phil
    Post photos by going down to bottom of reply and click Go advanced/Manage attachments and do what it says
    More descriptive info would help us answer What vehicle are you trying to do it in.. Would recommend you use the proper one and not have troubles to deal with
    Nov 2020
    Adeladie SA
    Talking
    Thanks for the reply.
    I got a bit carried away with the submit key.
    Its a 2012 Passat wagon, Highliner with sports kit TDI
    Phil
    Attached Thumbnails Attached Thumbnails Trailer Wiring-image-1-png
    Jun 2011
    Factory vs dealer fitted towbar
    Tiguan would have a similar setup to Passat. Just hit the local wrecker that has VW's or fork out for OEM module + a bit of programming via VCDS. The module integrates
    looks like the module you require is 1K0907383F
    Amazon uk Passat B7 tow kit
    Nov 2020
    Adeladie SA
    Excellent. Thanks
