1. Yes it will fit
2. You could be succeptible to the CANbus gateway battery drain issue, read more about it here:
Upgrading 2nd generation radios (RCD 300, RCD 500) to 3rd generation (RCD 210, RCD 310, RNS 310, RCD 510) power drain issue | my-gti.com
There are a few ways around this:
a) upgrade the CANbus gateway to a newer version (they are available on Ebay also)
b) upgrade the firmware in the CANbus gateway (you need someone with experience and the correct tools and software to do this
c) install custom firmware that swaps some files around to prevent battery drain issue (known as 'A' versions of firmware)
3. yes one from Ebay overseas (Europe) is fine. Just choose a reputable seller and get a rev C or later. Alternately buy one from a local seller who can assist if you need help. There are sellers on this forum
