Results 1 to 3 of 3
Thread: Polo GTI - Definitely needs tuning.
    Jul 2016
    Perth
    Lightbulb Polo GTI - Definitely needs tuning.
    G'day guys.
    Just picked up a cheapo '08 9N3 GTI. My first VW coming from a fairly modified BMW 330ci.
    Now. Because I thought it had the same 20v Turbo from the Mk4 Golf, I thought it'd go like a stabbed rat. How very wrong I was... I've been told it needs a tune, but we'll get to that later.
    Just picked up some coilovers and a set of OZ Racing Superlight 17s from Italy. Hoping to make it into a bit more of a hot hatch or a slightly spastic track weapon; apparently we can get close to 220hp with a simple ECU reflash, but I'm sceptical of that... Forums are always a good place to start, anyway!
    I look forward to chatting to you all about a bit of VAG.
    Cheers, Ash.
    Quote Originally Posted by Westw00d View Post
    G'day guys.
    Cheers, Ash.
    Hey Ash, I have tuned a large number of Polo's in recent times.
    220 is pretty ambitious, no chance without doing some hardware changes. You'll need to go to town on the downpipe, intercooler and intake.
    A stage 1 tune will net you 200-205 ish hp at the crank.
    The Golf GTI has a very similar engine but with a K03 turbo not a K03s and also it doesn't have VVT.
    If you are keen on a tune up I have an ECU with Stage 1 loaded to it. Which I can send you as a trial. If you like it, I can bench flash your ECU with the exact same software.
    If you want more than that, then I can work that out with you too if you don't mind doing a bit of logging.
    Jul 2016
    Perth
    Ripper! Cheers Gavin. I've just sent you an email to info@optimumcode.com.au - definitely keen to work out a tune for the old Polo.
