Welcome to the forum
I tried the solenoid replacement in mine however it wasn't the fix in my case.
Had the compressor replaced just before Christmas for $1k and happily enjoying icy cold air again just at the right time of year![]()
Have had the awesome R36 Passat Wagon for a few years now. Great family car!
Aircon started playing up a year and a bit back. A few dealers had a go at it and the only possible fix seemed replacing the compressor ~$1500,-
A very annoying problem as it still cools but sometimes takes up to 10min to start cooling.
Found this forum and a thread with a potential solution. We took a punt and replaced the compressor solenoid as mentioned in the thread ($25 part and an hour labour) - works like a charm again!
Wanted to post a quick thank you post on that thread hence joining.
Cheers!
Great tip to keep in mind on the solenoid. Mine is icy cold, however has another issue where -sometimes- the fans don't blow straight away from start up, they'll either kick in after driving for 5-10mins or after a re-starting the car. Found a couple of ppl with the same problem and they said it's worn bushes in the heater blower (under/behind the glovebox). Might try a blower from a wrecker and/or see if an auto electrician can fix the old one. Adding this to the do-do list prior to next summer!
2007 Passat V6 FSI 4Motion Sedan | Reflex Silver | DBA Slotted Rotors | ATE Ceramics | Pioneer Car Play |
| Emblem Reverse Camera | R-Line MFSW w. flappy paddles! | Supernova Headlight LEDs & Parkers |
On the radar: Chrome switches, engine mounts | Living vicariously through everybody else's mods!
