Originally Posted by
rgh0
How many Kms in that time
what sort of driving
was the car serviced in that time or before purchase
A few factors to consider
VW will not consider oil consumption a problem until it is more than 1litre per 2000km, engines are designed to use some oil and how much is difficult to quantify. Some engines use very little some use more
If a lot of water or other volativles build up in the oil due to city driving the level can drop if you then do longer country trips and run at higher tmperatures for longer preiods boiling off the water and volatiles
