noob passat melb
Originally Posted by
carloz182
Missus just purchased a used 2011 passat wagon, 118tsi.
90,000km's - had the mechatronics replaced mid 2016. Just noticed it has a slight shudder upon takeoff gears 1-2. Mechanic noted this at last service 4 months ago.
After a quick google i realise this is extremely common (should've avoided the dsg like the plague
Are VW likely to replace this again given it's out of warranty? Seems a bit ridiculous they can replace a part due to a recall and try to charge you two years on when it fails again...?
Any advice much appreciated!
It sounds like you have clutch judder so your DSG will now require a clutch pack. See if VW will do a good will gesture.
Mick
2018 Tiguan SEL 2.0TSI DSG dressed in deep black pearl. 2010 EOS SE 2.0TDI DSG Full leather, Retro fitted RNS510 OE Blue tooth and Media unit in glove box, 35 mm drop and running on 18,s.
