Results 1 to 5 of 5
Thread: noob passat melb
    Oct 2018
    Chadstone
    noob passat melb
    Missus just purchased a used 2011 passat wagon, 118tsi.
    90,000km's - had the mechatronics replaced mid 2016. Just noticed it has a slight shudder upon takeoff gears 1-2. Mechanic noted this at last service 4 months ago.
    After a quick google i realise this is extremely common (should've avoided the dsg like the plague ).
    Are VW likely to replace this again given it's out of warranty? Seems a bit ridiculous they can replace a part due to a recall and try to charge you two years on when it fails again...?
    Any advice much appreciated!
    Sep 2012
    England UK
    noob passat melb
    Quote Originally Posted by carloz182 View Post
    It sounds like you have clutch judder so your DSG will now require a clutch pack. See if VW will do a good will gesture.
    Mick
    2018 Tiguan SEL 2.0TSI DSG dressed in deep black pearl. 2010 EOS SE 2.0TDI DSG Full leather, Retro fitted RNS510 OE Blue tooth and Media unit in glove box, 35 mm drop and running on 18,s.
    Oct 2018
    Chadstone
    Quote Originally Posted by mickjane2 View Post
    Mick
    Thanks Mick, appreciate the response!
    Does anyone in Aus know if VW are likely to even consider this given it's out of warranty period and despite being serviced regularly, hasn't been getting serviced at the dealer?
    Should I go to a nearby dealer or contact VW australia directly?
    Oct 2018
    Chadstone
    So I turned the 'auto hold' off and no more shudder thus far...
    Odd
    Sep 2012
    England UK
    Odd
    Could it be the brakes just gripping for to long on auto hold as I have had similar issues if my car has been parked up for a few days, worse if it’s been raining.
    Mick
