Results 1 to 3 of 3
Thread: Newbie
    Apr 2015
    meadow heights Melbourne
    Newbie
    Hi
    I just bought a 2002 golf mk4 1.6L 5speed manual for my son who will be getting his licence in 6 months time.
    It needs some work due to its age, but my son and i are looking forward to getting some helpful advice from this forum.
    Alex
    Mar 2013
    Brisbane QLD
    Welcome mate..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    May 2015
    in my shed
    The biggest worry is the gearbox. If the code is DUU then the crown wheel is riveted on to the carrier. A lot of the time the rivets break and the crown wheel smashes the case from the inside.
    The proper fix is to pull the gearbox apart and replace the rivets with bolts.
    Check cambelt history and if the water pump has been replaced ( plastic impeller breaks )
    Also check the thermostat as it may be the electronic type and they can break and stick open ( plastic housing breaks )
    Use 95 Ron fuel as they run a lot smoother.
    Otherwise enjoy the car
    Always fixing my bora
