Results 1 to 9 of 9
Thread: New Here
    Jan 2018
    United States
    New Here
    Hello all!
    My name is Brett. I own a 2015 Audi A3 8V Quattro that I've been modifying.
    I noticed how engaged your members were in helping address issues, and I'm hoping to have some help too.
    I am having some coding issues in my computer that's throwing fault codes and I hope somebody can help me.
    Thank you!
    Jan 2018
    United States
    @dv52, especially your help with hex and long coding. I hope you or someone can help me.
    Jan 2018
    United States
    Here is the main issue I'm having:
    09 Central Electrics
    System description: BCM MQBAB MNA
    Software number: 5Q0937085AB
    Software version: 0134
    Hardware number: 5Q0937085AB
    Hardware version: H18
    Serial number: 01011414200106
    ODX name: EV_BCMCONTI
    ODX version: 013000
    Long coding: 04151A46C04122F541C0400451100700080000000000000000 0000000000
    Subsystems:
    System description: WWS371 140604
    Software version: 0585
    Hardware version: 042
    Serial number: 140607030124
    Long coding: 0A47F7
    System description: G397_RLFS
    Software version: 0002
    Hardware version: H06
    Serial number: 22735077
    Long coding: 00006C
    System description: E1 - LDS MQB
    Software version: 0032
    Hardware version: H05
    Serial number: 10 04 2014 00001013
    System description: Sirene, DWA
    Software version: 0311
    Hardware version: 004
    Serial number: 00000000000029984738
    System description: J245 PS73.014
    Software version: 0007
    Hardware version: H02
    Serial number: WOO29915178
    Long coding: 101F00
    Trouble codes:
    U101400 - Control module incorrectly coded
    static
    Jan 2018
    United States
    And a gateway issue:
    19 Gateway
    System description: GW MQB High
    Software number: 5Q0907530T
    Software version: 2186
    Hardware number: 5Q0907530M
    Hardware version: 212
    Serial number: 10061410801431
    ODX name: EV_GatewConti
    ODX version: 011017
    Long coding: 0101000820085A005B00020C180B0000000101000000000000 0000000000
    Subsystems:
    System description: E221 - MFL
    Software version: 0014
    Serial number: 04 06 2014 E0005777
    Trouble codes:
    U106A00 - Digital sound system control module No Communication
    static
    Quote Originally Posted by BMoneyBrett View Post
    19 Gateway
    ODX version: 011017
    Subsystems:
    Trouble codes:
    static
    Welcome to the forum
    First thing you need to do is post your full autoscan.
    Do you (or did you) have a factory fitted amplifier?
    What have you done (or tried to do) with coding or adaptation changes to these modules?
    Do you have an autoscan from before you started playing around?
    If so post that also.
    Jan 2018
    United States
    I was able to remove the code for 19. I tried modifying the Bang and Olufsen module in OBD11.
    My only issue now is 09, central electronics.
    I don't have VCDS, only OBD11. How would I scan and post a full scan?
    I have the factory Bang and Olufsen sound system with an aftermarket subwoofer and aftermarket subwoofer amplifier.
    Jan 2018
    United States
    I'm also getting P003000 - O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor after replacing both O2 sensors because I got a new high flow cat with downpipe. Not sure why that's faulting.
    Ah my apologies.
    Makes it a little more difficult but not impossible.
    A vcds autoscan if you can get one will make it easier.
    Do you know what you were changing before you had the BCM incorrectly coded issue? Just generally? Might make it easier to debug.
    Also you could compare you coding to a similarly specced vehicle reference scan in the Ross tech forums (don't change anything, just try and find one to compare against).
    Jan 2018
    United States
    Ah my apologies.
    Thank you for your kindness and swift responses. I can borrow my friends vcds tool for a complete scan and post it here in 2 days.
    I've changed so many modules that I'm unsure what I could have messed up in 09.
    I could try and find a similar spec vehicle reference scan too.
    The O2 Sensor is bugging me though. That's the main cause of my concern.
