Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: MK7.5 R-Line
    Oct 2017
    Quote Originally Posted by Kachingg View Post
    If you go lower in sidewall at the same time which you will need to do they will clear fine if your going wider tyres/rims than stock or moving the offset out you may need to check tho if its like 5mm or so i would not be to concerned unless your lowering your car then get professional advice before buying anything as it can save you lots of heartache and money
    If your set on lowering car if it was me i would lower 1st then get the rims/tyres that fit without rubbing doing it the other way around could be costly and embarrassing if you get it wrong
    Great advice actually!
    I have been looking at springs but only real place i can find them is ebay
    Oct 2017
    Godric's Hollow
    That look amazing
    Oct 2017
    Quote Originally Posted by MARK6 View Post
    That look amazing
    Thanks I’m super happy with it MK7.5 R-Line
    MK7.5 Highline.
    -Driver assist
    -Entertainment package
    -RLine package
