Results 1 to 10 of 12
Thread: Mk6 TSI 118 comfortline ower
    Mar 2015
    sydney, nsw
    Post Mk6 TSI 118 comfortline ower
    Hi, my name is sisilet. I have a 2011 golf mk6 tsi 118. I've just got a P0301 Cylinder 1 One Misfire Detected issue. and I'm looking for a more detail on how to fix it.
    Mar 2015
    Trieste, ITALY
    Hi , Have you checked the coil pack ?
    Mar 2015
    sydney, nsw
    Not yet. But how do i know if there is some problem?
    You'll be lucky if it's just the coil pack.
    There's a whole thread relating to misfire issues with this engine. Check the mk6 golf forum for the 118tsi thread.
    There are known issues with this engine and misfires is one of the first symptoms of a problem.
    Do some reading, get informed on the issues and then you'll be better placed to go through whatever diagnosis/warranty repairs that is needed.
    Good luck!
    Edit: I see you've already found the thread so you're on the way to getting your problem sorted.
    Have you checked if your #1 piston is still intact?
    Erskineville, NSW
    Swap the coil pack with another (#3 is a nice number) and see if the misfire moves.
    It might also be worthwhile to remove the spark plugs & see if one of them looks like it's been burning different (oily or very white). Maybe pop #1 plug back into #4 (to see if the misfire moves with it).
    If you have access to a compression gauge then you may as well check compressions while the plugs are out.
    I'm betting you've got cracked ring lands in #1. This will be covered under your statutory warranty rights if your VW warranty has run out (have a look at the ACCC website). Take it back to the dealer. Be polite but insistant & document the communications. Back verbal conversations with follow-up emails. Get VW Customer Service involved if the dealer starts putting up the stop signs.
    Don't accept "we'll supply the parts if you pay for the labour". Plenty of these engines have been fixed FOC when they are well past warranty expiry.
    Mar 2015
    sydney, nsw
    Thx all.
    So how did you get on? Or is this still an ongoing issue?
    Keep us posted on how you get on.
    Mar 2015
    sydney, nsw
    Just booked a check up next week. They will charge me $150 / hr for diagnosis.
    Mar 2015
    sydney, nsw
    It`s an engine low pressure prob. Vw said they can waive the cost of the parts and 30% of labour.
