5 months!!!
That's got to be something that can be claimed on the Lemon Laws
Lemon laws protect you | carsguide.com.au
I purchased my dream car in 2010. A grey Mk6 GTI manual.
A year later, the engine management warning light came on and the car started running roughly.
I took it immediately to a local dealer. That was 5 months ago. It's still there.
They have stripped down the engine and replaced many parts including sensors, heads, tensioners and timing chain. Still no joy.
VW Australia has been less than helpful on resolving the issues. Their Tech team keep looking at diagnostics (via email) and suggesting fixes but with no success. I've had enough. What recourse do I have? Can I "force" VW to just replace the entire engine? car? Anybody else with similar problems?
5 months!!!
Resident grumpy old fart
My previous car was a Mark V Jetta Turbo which suffered similar problems over a prolonged period. They eventually replaced the computer which solved the problem after a couple of minor issues.
this happened with dads crafter,
they replaced the entire engine and ecu,
Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
See if the dealer can get VW to replace the ECU then - it seems the most likely culprit left.
Just sent a letter of demand to dealer requesting a replacememtn due to "unmerchantable quality" of car in question.
Finally have my GTI back. They replaced the motor which is what I asked them to do after the 1st month of failures to repair. Forgot how good it was to drive...
