Results 1 to 8 of 8
Thread: Mk6 GTI Problems
    May 2012
    Bonner, ACT
    Angry Mk6 GTI Problems
    I purchased my dream car in 2010. A grey Mk6 GTI manual.
    A year later, the engine management warning light came on and the car started running roughly.
    I took it immediately to a local dealer. That was 5 months ago. It's still there.
    They have stripped down the engine and replaced many parts including sensors, heads, tensioners and timing chain. Still no joy.
    VW Australia has been less than helpful on resolving the issues. Their Tech team keep looking at diagnostics (via email) and suggesting fixes but with no success. I've had enough. What recourse do I have? Can I "force" VW to just replace the entire engine? car? Anybody else with similar problems?
    Oct 2010
    Melbourne, VIC
    5 months!!!
    That's got to be something that can be claimed on the Lemon Laws
    Lemon laws protect you | carsguide.com.au
    Resident grumpy old fart
    Jan 2009
    Sutherland Shire
    My previous car was a Mark V Jetta Turbo which suffered similar problems over a prolonged period. They eventually replaced the computer which solved the problem after a couple of minor issues.
    Jul 2011
    NEWCASTLE NSW
    this happened with dads crafter,
    they replaced the entire engine and ecu,
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
    May 2012
    Bonner, ACT
    Quote Originally Posted by kaanage View Post
    5 months!!!
    Purchased 2010 under old TPA 1974. CCA 2010 came into affect on Jan 1, 2011.
    Oct 2010
    Melbourne, VIC
    See if the dealer can get VW to replace the ECU then - it seems the most likely culprit left.
    May 2012
    Bonner, ACT
    Just sent a letter of demand to dealer requesting a replacememtn due to "unmerchantable quality" of car in question.
    May 2012
    Bonner, ACT
    Finally have my GTI back. They replaced the motor which is what I asked them to do after the 1st month of failures to repair. Forgot how good it was to drive...
