Could potenitally be the dual mass flywheel.
It'll be a deep, constant knock at idle, but go away when rev'd.
Hi all,
I was wondering if someone could please help me out with this.
I recently purchased a 2009 103TDI Comfortline VW Golf. I've noticed on occasion after I turn the ignition off, there is a knocking sound under the bonnet for a few seconds. The car itself runs fine and I've looked online and haven't managed to find any information about it. It doesn't happen every time I drive, at least not as far as I can tell.
The car does need a new pressure sensor which I am in the process of getting, and I have been told this doesn't affect the driving of the car.
Could the knocking sound be caused by the pressure sensor or is it something else? Should I get it looked at or is it normal?
Any help with this would be much appreciated!!
Thanks!
'07 Transporter 1.9 TDI
'01 Beetle 2.0
No not the dual mass fly wheel if it makes the sound for a few seconds after it's turned off, could you be more specific, has the engine stopped turning, or is it as it winds down to a stop, if it is as the engine slows to a stop then maybe yes flywheel separating, if after stopping it is something electrical that may be worn and knocking.
Cheers, Scott.
1976 Martini Olive Mk1 2 door Swallowtail
1981 black Mk1 ragtop GTI in need of some tlc
1979 Mk1 2 door - long term project
2002 Oettinger V5 Bora - daily driver
