Results 1 to 10 of 10
Thread: Install gti rack to tighten up steering/handling response in stock mk7 90tsi
    Dec 2014
    kyle bay nsw
    A steering rack from a gti would be nice but Generally what quick fix would tighten up steering/handling response?
    If you mean to make the steering a bit heavier the you could look at an anti-lift kit (ALK).
    This will make the steering feel heavier and improve turn-in.
    Dec 2008
    Sydney/Canberra
    Its the same rack, just different coding in the control module.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Erskineville, NSW
    Quote Originally Posted by jamieblaster View Post
    You might be able to change the steering weight via VCDS (you can in Polos). This won't change the feekl though - it's disconnected electric steering.
    Pump the tyres up to 36-38psi
    Fit more performance focussed tyres. eg: you've probably got ContiECO or ContiComfort - go to ContiSport or similar
    Fit lighter rims & possibly go +1 or +2
    Gosford Central Coast NSW
    FYI, Anti lift kit is whiteline marketing language for urethane rear (as in rear of the control arm) front lower control arm bushing kit, and has the same effect as any of the other good brands. They are all nearly identical in form but do vary in price.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Dec 2014
    kyle bay nsw
    Quote Originally Posted by Umai Naa!! View Post
    Hi Umai
    According to specs all Golf mk7s have the same turning circle 10.9mtrs but turns lock to lock are:
    Stock 2.75
    Gti & GtiP 22.2
    R 1.9
    Whats involved/price in converting mine to 1.9
    Thanks to all for the replies
    Dec 2008
    Sydney/Canberra
    Fit the smaller R steering wheel, and re-code the control module values to give the same 'weight' as the R.
    '01 Beetle 2.0
    I think you'd be the first. Not many people will bother with a mod like that - just buy a gti or R instead. I'm not certain about the mk7, but I'd not be surprise d if to change the rack complete engine/ drivetrains removal would be required.
    The labour cost will exceed the parts cost. At the end, perhaps let's say 5k later, you have a regular golf with fast steering. Its not going to be that awesome (IMO)
    '99 A4 Quattro 1.8T
    Dec 2008
    Sydney/Canberra
    Rack is the same for all Mk7s.
    From I've seen, they're not too bad to swap over. Just drop the front subframe out.
    '01 Beetle 2.0
    Erskineville, NSW
    Hi Umai
    Stock 2.75
    Gti & GtiP 22.2
    R 1.9
    I think you need to do a bit more research. Maybe use something like partsbase.org, vagfans.info or get a temporary ETKA to research partnos.
    Golf R with factory 19" rims had less turns lock-to-lock than the others because the turning circle was bigger. Maybe the 18s were different?
    Your just in Kyle Bay. Come over to Carss Park & get my VCDS cable & see if you can improve things slightly using software.
