Results 1 to 5 of 5
Thread: Hello!! from brizzy need some help
    May 2014
    brisbane
    hey guys my name is billy.. I'm new to the whole vdub scene.
    im in the process of doing a 2.0 tfsi swap (dsg) on my mk5 jetta (previously 2.0 fsi)
    i bought a wrecked turbo jetta with the engine running perfectly and swapped "everything" over.
    thats wiring, suspension, engine and gearbox and all the other stuff from the tfsi wreck
    reason I'm doing it was because there was oil getting into my cooling system which resulted in the car overheating.
    now I'm at the point where everything is in, immobiliser is working fine, fuel pump is working, the car is turning over
    but just won't start. i smell fuel after attempting to start it.. I'm stuck. i have a little super-vag computer and its throwing a couple of error codes. speed sensors ect. the only one that alarms me a bit is the cylinder 3 knock sensor. could that be
    the reason its not starting ? i just figured if it worked in the car before why is it not working now ?
    my cluster tells me "service now" I'm really stuck at this point. This is my first vw I've ever owned first one I've worked on
    I've worked on many jap cars and only owned only jap cars before. i recently bought an e30 convertible (big plans) and this as my jetta as my daily
    sorry for my introduction being off topic but this is how i ended up on this site
    would really appreciate it if someone would shed some light on what i should be looking for ?
    nice to meet you all if anyone needs any jetta parts just let me know
    thanks billy
    Quote Originally Posted by GASS View Post
    thanks billy
    What are the actual fault codes you have? A crank position sensor will stop it running.
    brisbane
    So you've swooped engine ecu from turbo dash cluster and key as these are all immobilizer components. If you've used the loom that came with the Turbo engine you shouldn't have an issues. Interested to see how you go where you located.
    Mar 2013
    Brisbane QLD
    Look into the crank sensor code first mate..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Aug 2007
    Def check codes, save and erase and recheck. If its getting fuel and no spark wont be crank sensor. They will throw crank sensor codes if the engine cranks too long therefore the crank sensor not at fault in that case but if its throwing cranks sensor code with minimal cranking def look into that. . So start from scratch. That's no mean feat swapping it all over and by the sounds you might just have left some off hopefully.
    Alba European
