Agreed and good luck.
If it's not your daily, it's well worth the experience and frustration.
Haven't done a TSI, but I've done a 1.8T and VR6.
LABEL EVERY CONNECTOR.
Of course parts and machine shops are hella cheaper in the US.
Hopefully some enthusits can give you advice. Vwvortex is the best for VW. Don't bother with the Australia regional forum and wear a flame suit. I've had buddies that have had bad luck with the TSI.
Check the recalls.
Did you buy it that way or just started having the misfire or the misfire is getting worse?
Is it throwing any cels?
First, get it scanned with VAGCOM.
The ECU will tell you all the problems.
You will have more problems.
My neighbors misfires, but it's him trying to make his 4cyld sound like my VR6. Pretty sure his turbo is stuffed it has a leak. It makes a popping misfire
It's not a bang, but a pop, pop.
Do you know what cylinder it is? Pull the coil pack slightly on each plug and pull on the throttle.
If it is the engine.
Remove the font end (it's easy)), drain all the fluids.
Get new engine mounts and an OEM Dogbone.
Change all the gaskets.
Clean the crap out of the engine bay and polish and was it.
Polish any meat parts You can.
Check hot. Fighting is hard on me when
