The best advice is to get them factory fitted or if buying second-hand look for a car that has them fitted from factory.
To do the aftermarket retrofit properly (i.e. As they would be installed in the factory) is expensive both in parts and labour.
Expect a "proper" installation with auto-levellers and washers to cost ~$5k. That's if you don't need a new front bumper. If you do then factor in another $1-2k depending if you have front park sensors or not.
- You may not post replies
- You may not edit your posts
Forum Rules
