Results 1 to 8 of 8
Thread: Golf MK7 Head unit firmware
    This may have been asked a million times but I will try anyway.
    Does anyone know where I can download firmware for the stereo head unit installed in my MK7 Golf? The details of the head unit installed are:
    Device Part number: 5G0035050a
    Hardware: H44
    Software: 0256
    Nav Database : 7810
    Any suggestions welcome.
    Thanks
    Pacific Paradise QLD
    Post a pic of it and if its newer than an RNS510 there isnt any except from a dealer and usually only if the unit has a problem.
    Thanks for the reply, see below.
    Golf MK7 Head unit firmware-20210222_201256-jpg
    Looks like a Discover Pro if it has no knobs on it so havent seen any firmware updates for them
    I meant a pic of the dash with it in it
    Oh sorry. pretty sure its MIB1 Discover Pro.
    Golf MK7 Head unit firmware-screen-png
    The car is an import from Japan so really what I'm wanting to do is convert it to NZ / AU. I have an ODB Eleven scan tool and have tweaked the head unit to the correct region and now receives the radio stations with the higher frequency.
    There are a few places here who say they will do the conversion but want $600 + to do it.
    This is what one commenter said on another forum:
    "Japanese imports need the region changed, firmware installed, maps installed, and activated to your cars VIN number."
    The spacing of Jap stations is different as well as in the 90's I had a couple of Jap cars and had to put a converter into the aerial line to make it pick up the NZ stations. They start at a lower frequency and dont go as high as NZ. Best try on the Forum that quote is from
    Actually I found this was fairly easy to overcome with ODB Eleven.
    Go to Control Unit 5F (Multimedia)
    > Long Coding
    For FM Band
    >Byte_9_Band_Settings_FM_Tuner
    > Select EU_RdW
    For AM Band
    > Byte_9_Band_Settings_AM_Tuner
    > Select EU_RdW
    Golf MK7 Head unit firmware-screenshot_20210226-211023_obdeleven-jpg
    Apply
    I can now scan for all the NZ radio stations from 87.5 t0 108 MHz
    Golf MK7 Head unit firmware-20210223_215527-jpg
    credit to this guy for the above solution
    Change radio frequency region in MIB1 MIB2 Audi Volkswagen - YouTube
    navigation is the one I'm trying to solve which I believe requires the head unit to be updated with NZ / AU region firmware.
    Apr 2022
    New Zealand
    Did you find a solution to change the software from Japan to NZ?
