You need to buy the full wiring kit either way, whether it's pre-wired or not.
Being an 07, it won't be pre-wired. They're not exactly plug and play, either.
Hi Guys and Girls
First time VW owner here, although I have now had the car 7 years.
I need some advice regarding what additional wiring (genuine VW) is required when adding a towbar. I have a 2007 TDI Passat wagon and recently bought a genuine VW (Best Bars NZ) 2nd hand towbar with what I thought was all the VW electrics (Westfalia), e.g. module, cable from module to towbar and various adapters. I wanted all genuine so I could just run cables, plug in and know that all was compatible with all existing electrics/ systems.
Unfortunately for me I didn't realise, in normal production, VW dont run the towing pack cables from the fuse box/ CAN to the rear of the car in readiness for a towbar install.
Hence my questions. 1. Does anyone know if the cable I am missing is in fact "pluggable" into the fuse box/ CAN and run to the rear of the car? 2. Anyone know where I could purchase this genuine VW cable separately from the normal towing pack electrics which I already have 70%? VW parts have advised they don't have!
Thanks for advice. I realise there is zillions of posts on towbars/ electrics but I cant find one which answers my questions.
Thanks Umai Naa
I thought as such!
I have located the below kit and spoke to the guys on the phone who were very helpful. All things considered I think I will get one of these kits, have the guys install it to complete my partial install, update CAN setting and test. I think it will be money well spent considering what I have saved overall.
Thanks again for your comments.
Volkswagen Passat B6 B7 Tow Bar Wiring Module kit LED Towbar VW OEM Westfalia - Australia Tow Bars store
Excuse my ignorance but back when Jesus played fullback for Jerusalem we just spliced the new wiring into the wiring loom that fed the rear lights. Wouldn't this be the simplest way?
1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
1991 MK2 GTI 2.0 8v, white (RIP) and it's red replacement http://www.vwwatercooled.com.au/foru...gti-42078.html
1997 MK3 CL http://www.vwwatercooled.com.au/foru...ml#post1292061
2001 & 2002 Bora 4motion. http://www.vwwatercooled.com.au/foru...st-123823.html
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
Tail lights illuminate from a signal generated by the central electrics module. They're a pulse width modulated signal, so won't always be the full 12/14V.
The stop/tail bulb for example, uses one filament for two different light functions. All they do is up the juice, to make it a brake light.
Yes, I used to do the old splicing trick for everything years ago but wouldn't attempt it on new cars unless I was 100% certain the circuit wouldn't be effected.
As an update - I was lucky enough the guy I bought the towbar off was able to remove the additional wiring I need. Turns out it goes to both the drivers and passengers fuse boxes. Once I receive it I will provide an update on my progress on completing the install.
Thanks again for all the comments.
How did you end up going with this?
