Hi There,
Wonder if someone can make sense of the connection below. I am assuming I'm to solder these cables to the harness with the 1 to 26 pins connector but the
description below does not appear to match the description on the drawing of the RNS unit.
VW Amarok High line Rear Camera kit - 2H0907441
There is four wires: Power (RED), Ground (BLACK) and Can + (ORANGE) and Can - (BROWN) to get hooked up. All of these get tapped behind the RNS/RCD510 and it's worth noting that the pin out is listed on the device anyway if you want to double check:
Pin 9 - CAN+ (Wire Orange/White)
Pin 10 - CAN- (Wire Brown/White)
Pin 12 - Ground (BROWN)
Pin 15 - +12v (YELLOW/RED)
