Results 1 to 3 of 3
Thread: Front parking assist buzzer replacement.
    Apr 2022
    WYNN VALE SA
    Hi all. I need to replace the front parking assist buzzer H22 which is located above the fuse panel. I can access the fuse panel and can even see the buzzer at the top of the fuse panel but I simply cannot get my hand in there to remove it. Is there anyone out there that can help with this problem? Surely the fuse panel can be removed or at least enough to gain access to the buzzer. Any help would be greatly appreciated. Thanks
    Pacific Paradise QLD
    Might help if you state which car you are working on as most of our crystal balls are fairly worn out
    Apr 2022
    WYNN VALE SA
    Oops sorry Hillbilly. Its a 2013 Golf 7 Highline. I was wondering if I removed the Glove box compartment would that give me enough room to access the buzzer?
