Results 1 to 4 of 4
Thread: Another noob! T4 TDI syncro.
    Oct 2018
    Hobart Tasmania
    Hi all, recently (July) purchased a 2003 T4 TDI SWB syncro.
    Slowly working my way through maintenance issues. So far done timing and injection belts, tensioners, water pump. Replaced all engine and gearbox fluids and filters. Fitted cruise control, repaired wiper switch, fixed intermittent wipers ("99" relay had been swapped into incorrect location). Repaired fuel sender to fix extreme hard starting from air leaks into fuel system just under 1/2 tank full. Built a rock n roll bed with slide out kitchen bench. Replaced faulty igntion switch.
    Next to do list is fix air con, modify and fit second hand bull bar, build rear wheel carrier. Auxiliary battery electrics for rear camper stuff. Maybe look at remapping? Tidy up electrics where some idiot has fitted a second immobiliser over the top of the standard one.
    Any tips on to do list items gratefully accepted!
    Other interests: motorcycles Honda xl350, BMW K100, Yamaha XS 1100. Sidecars. Peugeot 308 HDI. Navara STX diesel. Workshop time welding, lathe, milling machine.
    cheers,
    Brewer.
    May 2006
    Adelaide South Australia
    Welcome to this forum Brewer. You sound like you are very capable mechanic & interesting person with your interests. I don't know how many Syncro owners there are here but I have met another who lives around an hour from where I live. We recently worked together replacing all the belts & water pump on both of our vans He is around 20 years younger than I am & can get up & down much quicker than I can.
    How many ks has your van done?
    Numerous Mk1 Golf diesels
    Oct 2018
    Hobart Tasmania
    My Syncro has 192000 km or the clock, I have done about 5000 of those. I bought it sight unseen with "timing belt failure" but fortunately only both tensioners had failed and timing jumped 1 tooth, no damage. It is ex hydro electric co, has quite a few options, dual airbags, abs, edl = "electronic diff lock" - really just traction control. Dual battery pirahna controller, air con but not working, reverse camera, towbar. I have been getting around 7.5 l/100 km so quite economical. It has had the short shift gear linkage mod previously done. Very comfortable to drive, all in all I am rapt! The 4wd is quite capable even to the point that the 4wd Navara is hard to justify keeping. Cheers, Brewer.
    Oct 2018
    Hobart Tasmania
    Forgot to ask, Jets, do you have a copy of wiring diagramme that you could send me to help with the air con trouble shooting. Thanks, Brewer.
