If I can remember right on my 2018 Tig you just press the center button on the right side of your steering wheel to make this happen. If not then your Tig must still be under warranty.
Mick
Hi Guys, new to all this so please bear with me. I have a 2018 Tiguan Highline 162 RLine with active info display. The issue i am having is as of today the dials no longer shrink to a smaller size when the satnav is selected. Any one else had this issue and any suggestions on how to fix it.
Mick
2018 Tiguan SEL 2.0TSI DSG dressed in deep black pearl. 2010 EOS SE 2.0TDI DSG Full leather, Retro fitted RNS510 OE Blue tooth and Media unit in glove box, 35 mm drop and running on 18,s.
Looks like VW will have to look at it when it goes in for it's next service. I think this is what they call the VW experience, lots of little annoying things go wrong.
Have you got the word NAVIGATION above the screen IF not change it with the silver outside of the r/h steering wheel button
Press the "OK" button on the steering wheel to cycle between the small and large dials...
Thanks for the suggestions, already know how to use the system,had the car for 18 months without an issue with the dials. Only started to do this in the last week.
Solved the issue. Thinking back the problem started when i switched from 2D to 3D on the dash map view so i switched back to 2d and the dials got smaller. Have gone back to 3D and the dials have got smaller. Looks like it's fixed itself.
