hmm...... I suspect this car has the new DNN 2.0TFSI TSI 190PS engine which has nominal power-rating of 140KW and which produces 320Nm of torque!
Maybe read -HERE
Confirmed by engine bay sticker - only 3 letters DNN
Maybe the Spanish don't get all 4 !??
Maybe read -HERE
Thats both good news and bad news ... Great that it does indeed have 1 of the EA888.4 variants, the MK8 Golf GTI still on a EA888.3 !!!!
Bad in that none of the tuning options out there will work on it at the moment. You will probably have to be a bit patient and let the tuners do their magic. I would not be putting any JB module on it as none of their options (at the moment) are designed to work with that particular engine.
Cheers Don - what is interesting is that the compression ratio is quite high !
Your link states 12.2:1, whilst the Official brochure lists 11.7:1 (the 180kW versions in the VZ model list 9.6:1 compression, whilst the VZx 221kW model is listed at 9.3:1).
Love to know more about the "new turbo" though !
Here is another link from VW, but no mention of the 190HP (140kW) variant !
The EA888 Evo4 engine: A performance spearpoint sharpened - Volkswagen US Media Site
I'm starting to agree with you there but get all sorts of answers here and there.
And re the JB4, after confirming some details with Cristian (Autoinstruct), including that the TMAP sensor was 3 wire (not 4) that this Burger Motorsports JB4 Performance Tune '-' VW MK8 GTI | AutoInstruct (Burger Motorsports JB4 Performance Tune – VW EA888 Gen 4 MK8 GTI – Group 17) was the one.
Hmmm, may still wait a bit. Still have the Wheel speed sensor issue to sort and get rid of the pesky lights before I delve any further.
Thats direct injection engines for you. Gone are the days of old school turbo RB's, 1J's, 4G63's and SR20's with low compression ratios. Its really only the higher powered models that are a bit lower compression.
Lots of the modern direct injection engines are above 10.0:1 compression ratio. Even my little Fiesta ST has a 10.1:1 compression ratio and that is a relative old direct injection engine these days.
@Michael_B
See attached document for VW 4-cyl. direct injection engine (2.0l, 4V, TSI, EA888evo4) engines.
Your engine code is actually DNNA.
Can't attach document just now but this is the info from it.
2.2.1 - Engine data - DNNA
Engine code - DNNA
Power class - LK1
Emission standard - EU 6
Displacement l - 2.0
Power kW at rpm - 140 at 4200 to 6000
Torque Nm at rpm - 320 at 1500 to 4100
Bore Diameter, mm - 82.5
Stroke mm - 92.8
Compression ratio - 12.2:1
Intended fuel - RON 95
Injection system - Direct injection
Firing order - 1-3-4-2
Charging - Turbocharger
Camshaft timing adjustment - yes
Variable valve timing - Inlet side
Secondary air injection - no
Valves per cylinder - 4
Oil pressure control - yes
Particulate filter - yes
Flipper Dog
Now - T-Roc R, Audi Q5
Many thanks, would love to get a copy of the document at some stage.
Thanks for the engine code confirmation
Was is this pdf document from here ?
https://esperformance.net/ssp/audi/SSP_683_DE.pdf
EDIT : I've managed to translate the doc from German to english, but can't seem to upload/attach a pdf document.
Happy to share both versions if anyone is interested.
Michael
The MK8 GTI is a different engine (for instance 9.6 compression vs 12.2) to yours. If you put the JB suitable for a MK8 GTI on your engine, you will take a significant risk in relation engine failure. Further Aus MK8 GTIs run EA888.3 vs EA888.4 for UK and USA versions.
