Results 1 to 2 of 2
Thread: 06 Golf TDi trendline (pov pack) driving me spare.. :)
    Dec 2014
    Queensland
    my names Chris, 6 months ago I bought a 2006/07 tdi trendline as a daily work hack, I am currently trying to put cruise control in as that is really the only thing I wish I had of paid more attention to when I bought the car (lowline display without mfsw). I have the stalk, a micro-can cable and upgraded steering control module, when I plug the new steering control module in it reads the horn as being activated, after a couple of seconds the ecu stops the horn and logs a short to ground fault for the horn. once I configure the steering wheel control module for no onboard computer with ccs and enable the engine coding for ccs the cruise works fine but the horn is still activated, if I plug in the old steering module the horn is fine so I have complete confidence it is a coding issue. if I leave it as it is the horn goes off every time I turn the key to "on". if anyone could direct me to where I can change/check this it would great as I am really stuck.
    BTW, im not new to ECUs or engine management tuning but this vcds canbus coding is still very new to me.
    Mar 2013
    Brisbane QLD
    The horn going off sounds like a bent pin...done it myself. Also you have to go into engine ecu and "activate cruise control" to make it work...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
