Results 1 to 2 of 2
Thread: Windscreen Wipers and RNS510
    Jun 2009
    Ringwood Victoria
    Hi All
    i have some problems with the windscreen washers. They spray too wide and high and go all over my sunroof and the side windows. On a black car it makes it dirtier than it has to be. Has anyone come across this. The dealer adjusted them so they are a bit lower but it still does the same thing.
    Also with the RNS510, i have turned off bluetooth activation. I have an iphone that is hooked into the bluetooth hands free system. and everytime it gets an email or a message, the RNS510 comes up with a pop up box saying if i would liek to ACTIVATE BLUETOOTH. This is annoying. I have ticked in the setup not to activate bluettoth
    Regards
    Dec 2008
    Alexandra, New Zealand
    The windscreen spray is probably adjusted so it's OK when you're traveling at speed. I'm sure it will be able to be adjusted lower as mine doesn't spray anywhere except where it should.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
