Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 96
Thread: Wastegate rattle can now be fixed!
  1. #41
    Quote Originally Posted by ido09s View Post
    I wonder if they would just supply me the clip?
    I cant be stuffed waiting an hour for something that realistically probably takes 10 minutes.
    They would probably wait longer to do mine as well as i have a half hour run up the freeway to do before i get to the dealer
    I beleive it only takes about 5-10 minutes to fit.... but a good hour for the turbo to cool down.
    Fortunately my local dealer is only up the road from my work so it's not such a hassle.
    Sep 2011
    Townsville, Nth Qld
    The dealer that did mine took half a day - had to take all the pipework (and turbo?) off to do it (apparently). I know - I didn't believe it either
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  3. #43
    Got mine done the other day and yes rattle at low revs under (heavyish) acceleration is now gone. Happy days
    Apr 2012
    Is this happening to MY12 as well?
  5. #45
    I'm not sure if they fixed it in MY12. If you don't hear a rattling sound then you don't have a problem.
    Usually happens under heavyish load at low revs.
    I suspect it only happens/gets complained about on some vehicles so they just do the fix when people complain.
    Dec 2012
    Hills District, NSW
    Quote Originally Posted by alanzidane View Post
    I had the rattle fixed on my My12 132 pacific.
    I could hear mine on freeway, 2500 -3000 rpm mild throttle load.
    Hard to notice when you have it, but so quiet once it's fixed.
  7. #47
    Mar 2012
    Yes it is. Mine is a 2012 model and i have the rattle.
    From about 2200 to 3000rpm you will hear it. It almost sounds like the turbo spoiling up in a really bad way lol
  8. #48
    The fix quietens it down a lot but is more muted than fixed.
    You may need to get your service advior to come for a test drive or they may just book it in for the fix.
    Feb 2013
    Perth, WA
    My 155 (only 3 days old) has it. It's an MY13. You would think that if they have known about the problem for 2 years, then they would address it. Oh well, I'll try and get them to address it on the 1000km checkup.
  10. #50
    Sep 2009
    Perth
    As above, girlfriends brand new 132 has it. My 4 month old GTI has the same issue (now fixed though). Poor effort they haven't fixed it from the factory.
