Unfortunately, it's not just a simple job of replacing just the tensioner.
By the time you've pulled the lower chain cover off to access it, which is single-use, meaning new cover plus the correct sealant, you may as well do the whole job properly, and replace the upper and lower timing chains and all the guides. The guides wear, the leading edges break off, and the chains wear to the point of growing in length.
It's not the kind of thing you'd do half-hearted.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
