I have an -{ 5N SUV 2.0 TDI 4motion AWD Diesel 2.0L 4cyl 103kW CLJA,CFFB,CBAB 1968cc 103kW (Diesel) } -
the ABS and Traction lights are on as soon as i move and flashing brake service light as well , scan says all 4 wheel speed sensors
are at fault " Fault In Circuit " but live data scan shows all wheel speed sensors reading correctly .
Mechanic confirmed all inputs for ABS module are present and within specs , ABS motor is not activating when ignition is on ,
Fault within ABS module.
VW quote $3000 dollars for new ABS module ( part number 5N061419QBEF ) has anyone been though this problem ?
Mechanic says second hand module not an option due to coding problems VW will not comment as there interest wanes with older
vehicles , any input would be much appreciated , especially if anyone has had success with second hand option .
Thank you in advance.
