Hi guys.
So I've done a bit off off-roading with the Tig, and learned along the way that I needed more precautionary equipment to improve my chances of recovery if I do something silly. I also tend to camp when I go off-roading, and there's come camping extra's I'd like to always have with me. The problem is, the Tigs boot space is a little limited, so I didn't really want to give any up to stuff I may (hopefully) never use.
Anyway, long story short, this is what I've managed to do with the limited space around the space saver wheel:
In the middle of the space saver I've put:
- a tarp (think it's 7mx6m) - for shade, ground sheet, sand or mud recovery if desperate, etc.
- a couple of elastic bungee cords - always useful I've found
- leather gloves - protect my precious office hands
- wheel spanner - much better than those useless ones that come in the tool kit
- nylon strap - just had it so thought it could be useful at some stage.
In the close edge I've put (left to right):
- wheel sockets - coz sometimes it's someone else's wheel that needs changing
- kayak tie-downs - for when carrying the kayak, but also generally useful for strapping stuff.
On the left side of the wheel I've put (top to bottom):
- can of tyre weld - pretty handy for small punctures
- tubeless tyre repair kit - for the bigger punctures
- foot pump - I would have loved to get an electric one, but size and price limited me. Plus, you can always count on manual pumping power without worrying about the little pump overheating and failing
- 1m long wheel socket bar (under footpump) - useful for leveraging off those horribly overtightened wheel nuts from tyre repair shops that don't use a torque wrench to tighten the nuts, but instead try to strip the threads when tightening them (yes, sore point! I have arguments with idiots all the time about this)
To the right of the wheel I've put (top to bottom):
- jumper leads - having been caught out by a flat battery once, I will not be a victim again!
- nylon kayak stern rope - again, usually for securing the nose of the kayak to the front bumper, but useful for other stuff too
- 1l engine oil - common sense to have this really
- 2 x 4m heavy duty nylon ropes with hooks and red flags - good for pulling stuff out of your way, and if desperate, other vehicles
- toilet roll - again, common sense thing to have, especially if you've ever been caught short in the bush!
- a few elastic bungee cords
- 2 x ratcheted tie-downs - at this point you're probably wondering what more I want to tie to the roof!
- 10 ton rated kinetic/snatch recovery strap with heavy duty hardened steel bow shackles - for sand and mud recovery.
- small collapsible shovel/pick (sits on top of snatch strap but you can see it propping up the boot cover in the pics above) - for sand and mud recovery too. Also generally useful when camping I've found.
Then in the right hand side pod of the boot I've got another can of tyre weld, diesel smoke killer, first aid kit, and some more bungee straps.
So, what am I missing? The only think I can think of is a fire extinguisher and some form of bog-recovery (mats, planks, or maxtrax type things that are flat and will not rob me of space. I'd also quite like to get another screw in recovery eye so that I can fit one both at the front and back of the Tig before going adventuring. Any idea where I can get one and how much?
Any suggestions, tips, or general comments are welcome.
