Page 7 of 26 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 254
Thread: Tyres - what did you get?
  1. #61
    May 2009
    Melb
    Got Bridgestones.
    Asked about the first service, and was told nup, see you in 15000. That was from Barloworld Glen Waverley.
  2. #62
    Aug 2009
    ferntree Gully
    Tires on a tiguan.
    I thought i would fill this in.
    I have driven Tiguans On 7 different types of tires
    all the same cars.
    the way VW works is they are not tied down to a specific tyre supplier.
    otherwise there could be a wait..
    i assume they negotiate with the distributer for a batch of each tire.
    you may have any of the following.
    Bridgestone Dueller HT
    Hankooks
    pirelli scorpions.
    goodyear eagle (18s)
    continental conticrosscontact (18s)
    kumho
    toyos
    it is pot luck what you get.
    i have driven on all of them and i find the Hankooks are the nicest and quietest to drive on.
    Each to their own though.
  3. #63
    Sep 2009
    morningside qld
    picked up new tiguan 2 weeks ago. got the hankook tyres. i was very suprise. hope it last. the fuel door said the tyre pressure is 220. i checked it and the tyres were 250. so how much should i pump it up? the care thread said 10% less so should i pump it up to 200? i got it at 210 now it seems low. what should it be?
  4. #64
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Quote Originally Posted by tig10 View Post
    I have my front tyres at 36PSI and back at 34 or 35PSI.
    The Care Thread says 10% less than the TYRE MANUFACTURERS recommended max, not VW's. If you look on the tyre wall you'll see a max pressure recommendation. That's the number you use and take 10% off of AS A GUIDE. There's no hard and fast rule though. If you travel on rough roads (eg farm roads) it's a more comfortable ride if you make the tyres a bit softer. For better fuel economy make them a bit harder (but not too hard otherwise you get excess wear in the centre of the tread and you may lose traction because the tyres contact area is decreased).
    Hope that helps.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
  5. #65
    Adelaide hills, SA
    Every tyre brand is different. I'd start with 38psi front and 36psi rear and than watch the tread area to see if you're getting an even wear (tread depth should be the same, sides and the middle). Drive 1,000km than correct the pressure, if the wear is not even.
  6. #66
    Jun 2009
    Seattle, WA USA
    My 2.0T 4Motion in the US came with Michelin Latitude HP but I don't think they are very common as OE tires. I'm super glad I didn't get any of the others because I plan on selling them and they're the most expensive. Gonna go with separate winter and summer wheels/tires.
  7. #67
    Sep 2009
    morningside qld
    checked the tryre wall for pressure. the hankook says max 44psi so if i were to -10% if i inflate it to 40psi it seems quiet high. any suggestions
  8. #68
    Dec 2008
    Alexandra, New Zealand
    My diesel has the figures in the fuel flap and suggests 32 all round for normal use and 36 front 39 rear for high loads.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
  9. #69
    Erskineville, NSW
    This seems like a suggestion
    or this
    Tyre pressures are a fairly subjective thing.
    As it appears the minimum factory recomendation is 32psi all round & the maximum (tyre) manufacturers limit is 44psi, then Nirvana lies somewhere inbetween. Experiment a bit to get the ride & handling compromise that suits you, your driving style, the roads you drive on & the tyres that are fitted.
    My suggestion: either 36F/36R or 36F/34R
  10. #70
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Well, I'd given you what I set mine at before (36 front, 34 or 35 rear) but here's another way you could do it:
    Find a quiet car park with a smooth concrete floor. Set your tyre pressures, then evenly sprinkle talcum powder for a couple of meters in front of each wheel. Moisten each tyre and then drive your Tig forward a couple of meters over the talc powder. Check what the contact pad of your tyre is by where the talc powder has stuck to it. If the powder doesn't go to the tyre tread edges thent he tyre is too hard and the tread will wear in the centre. Release some pressure (1PSI?) and test again.
    ...or you could just take someone elses advice. As far as the pressures recommended on the inside of the fuel flap go, I have found that to be way too soft for general use and the shoulders wear on the tyres. The only time I'd run the tyres softer is if I am traveling on rough roads like gravel roads.
