Results 1 to 8 of 8
Thread: Tyre size increase ?
    Mar 2010
    South Africa
    My Tiguan has now covered 41 000 km , and the 215/65 R16 Pirelli P6's have reached the wear indicators.
    Because of pothole-ridden roads in SA I am contemplating going to 215/70 16's.
    It will better the ride quality as well as give a little more rubber to protect against rim damage....
    My car is the Track & Field version, so a slight increase in the aspect ratio will not look out of place , IMHO.
    Please talk to me?
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Hi. Yeah, I have been thinking about what tyres to go with when my current ser wear out. I also currently have 215/65x16's on but was also interested in a slightly wider tyre. I was thinking of going 225/65x16 which would keep me within the 4% variance on OEM tyre laws that we have here in Aus. I would not give as much extra tyre sidewall as what you are suggesting, but still better than OEM.
    BTW, if you say SA people on here are probably going to be thinking "South Australia" as it's an Aussie based forum
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    Mar 2010
    South Africa
    Quote Originally Posted by Arctra View Post
    Nah, we're properly informed ... with half our neigbourhood already over on your side and all ...
    Dec 2008
    Alexandra, New Zealand
    Have a look on this site as it will allow you to calculate the effect on your speedo etc
    http://www.miata.net/garage/tirecalc.html
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Nov 2007
    Quote Originally Posted by CanAm View Post
    Even this forum has plenty of them .....
    Go the larger profile, you can change your speedo correction with VAGCOM. Also, I suspect using the winter tyre option in the MFD settings will be OK. Will have to chec the manual for that.
    Sep 2009
    QLD
    I'm all for going to a 70 series tyre when ours are due. Looking at similar to Cooper ATR or ST in 215/70x16. Not worried about the speedo difference as that can be corrected. In a LT (light truck) variant you will get a much stronger tyre than the 'passenger rated' tyres the cars are shipped with.
    2010 Candy White TDI Auto, black leather, bi-Xenons + fogs, DVD plus other gadgets and gizmos to keep the kids quiet!
    Sep 2009
    Harbord, NSW
    Having a quick look at the web - Cooper don't do the ATR in LT215/70x16 its still passenger construction and they don't do the ST in that size at all
    BFGoodrich do the AT KM in LT in 215/70x16 which could be a good all round tyre for the Tig.
    Depending on the size increase you might have to think about wheel offset as the tyre is pretty close to the suspension strut as it is. I think a 215/70 should be fine as its about 10mm increase in radius, but a width increase 225/65 might rub (if you can find a tyre in that size)
    2010 103TDI MANual, offroad kit, nuffin else
    Sep 2009
    QLD
    Quote Originally Posted by duncan View Post
    No worries. There's a few brands that would something to suit. I have used the BFG A/T in the past and they were very good too. There would no need to go to a more aggresive pattern than that. Mickey Thomson also do some good tyres... either the ATZ or FCII would be excellent as well, although the smallest they do is a 265/75x16. Maybe a bit large for the Tig.
    http://www.mickeythompsontires.com.au/tyres.htm
