check this topic i am sure you find the answer here
http://www.vwwatercooled.org.au/newf...ad.php?t=29669
My tyre pressure indicator went off on the weekend while driving , alerting me that one of the tyres was going flat which was great, Pulled into the closest servo to check the tyre pressure and low and behold the rear left showed it had 25psi , What i am wondering is, what is the standerd tyre pressure on the 18" wheels ? cause as i checked the tyres i noticed that the
front right had 41 psi, the front left had 42 psi and the rear right had 40psi. so i looked all over the car to see what the standerd tyre pressure loads are and found it in the petrol cap/ flap but could not understand how to read it. I ended up inflating the fronts to 42 psi and the rear to 40 psi . would anyone know if thats correct ..![]()
08 MkV GTI Pirelli --- 65 Split Screen Container Van
Hey Ultra, glad to know the tech saved you and your tyre.
As far as tyre pressures go, as I put in the care sheet, the rule of thumb (that I use anyway) is tyre manufacturers max pressure as displayed on the tyres sidewall less 10% of that max pressure. So my tyres have a max pressure of 40psi so I pump the fronts to 36psi (40 less 10% of 40).
I did some testing this weekend though, and came to the conclusion that in my Tig, with the boot emply and a full tank of fuel, I need to have the back tyres 2psi lower in order to have approximately the same contact patch. So I run 36psi on the front and 34psi on the back. But I have 215/65R16's on my Tig, you'll have to play around to figure out what you need to do on yours.
Tiguan TDI, 6spd Tiptronic Auto
Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
Avg 7.63L/100km over 189,000kms
thanks for that guys will look at it first thing when i get home..
ok this is what i found , 18" wheels max psi is 51psi subtract 10% you get 45.9psi. So we are looking at the fronts at 45 psi and rear at 43 psi.
The first thing that I would be checking is why that tyre pressure was so low in the first place.
Ive had a good look around the tyre and could not find anything noticable. But now that has happened i will be checking the psi of that tyre everyday to see if it is still leaking and if so will have to get it repaired..to be so low there has to be something but can't jump to any conclusions yet..
After a pressure check on a chilly morning, i began to wonder what sort of difference i should expect between hot (been driving), ambient (normal/average temps before driving) & COLD... (about 8 degrees when checked before a drive yesterday)?
The reason i ask is that i normally run 36psi all round, but when checked (with my own 'good' guage i keep in the glovebox) yesterday (chilly) i had a readings of only 30-31 all round!
So i did a bit of a search, found this thread, went out to the garage & read the max pressure for my tyres is 50psi & if applying the above philosophy, i should be inflating to mid 40's... Does that sound about right? Rolling on 19's, 245/40 Bridgestones.
Thanks in advance for thoughts, scientists!![]()
Hi. New to these, so could be wrong. Tyre pressure placard inside fuel filler lid says 2.2 bar, which I convert to 32psi. Seems low I know, but that's pretty much what was in the tyres. Wouldn't want any more in there as ride is already pretty firm (certainly not squishy). Maybe less than normal because are 18" with 235/35 tyres?!
2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
Would have to say that in my personal opinion I'd be looking at what the manufacturer of the vehicle recommends rather than taking any notice of the max pressure given by the tyre manufacturer. I would say that 32psi on 18s would be about right. My specifications from the sticker on the fuel flap are 32psi all round with 2 people and 36 front 39 rear fully loaded, and I run 34 all round for convenience.
Derek
Alexandra
2022 R-Line Golf Mk8 in Kings Red Metallic
Previously 3 Tiguans 2008, 2013, 2017
