Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Tyre pressure indicator
    Feb 2009
    Sydney, Australia
    I disagree NZTiguan.
    The tyre manufactures "max pressure" should ALWAYS override what the vehicle manufacturer says. What does Volkswagen know about Tyre Company A's Model B tyre's composition? Probably nothing.
    The "max pressure" is just that. The max, and you should NEVER exceed that.
    Thankfully, most tyre's max pressure is always more than what the tyre placard from the vehicle manufacturer recommens anyway. So in that regard, yes, follow the placard in the fuel flap.
    Just always take the tyre manufacturers "mins and maxes" as overriding factors to what the vehicle manufacturer says
    Dec 2008
    Alexandra, New Zealand
    Quote Originally Posted by Corey_R View Post
    I certainly agree that you shouldn't exceed the tyre manufacturers max limits and I never suggested you should BUT I also don't think using those limits and subtracting a percentage to give you your tyre pressures is what you should do !! That's what I was saying, not that you should ignore what the tyre manufacturer states. Mind you, personally I've NEVER even looked at the max allowable pressure on my tyres except for my wheelbarrow !!!
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Feb 2009
    Sydney, Australia
    Yeah, agreed
    Erskineville, NSW
    My way of fine tuning tyre pressures is to start with the tyre placard recomendations & recheck after 30-45mins of driving in your "regular style" with your "regular load". If pressure increase is more than 10% of what you started at then the starting pressure is too low. Add 2-4psi & repeat the next day (because you have to start with cold tyres).
    Generally the manufacturers recomended plus another 2-4psi works for me.
    32psi in 18s? Seems a fraction low. Sure the ride might be comfortable but the tyres aren't there to be a suspension component. If you want to avoid impact damage to the sidewalls & flat spots on the rims, I'd run 34-36psi as a minimum.
    Sep 2011
    Townsville, Nth Qld
    Hi mate. I know what you're saying - I used to run 34-36PSI in my Forester, but it had much higher profile (215/70 R17). I feel the extra sidewal height DOES make a difference (especially on our S*&t roads). Have read & seen many car reviews that agree. Bump absorption is very good, but ride noticeably harsher than Foz. Will try bumping them up to 34PSI and see how it goes (when I can find decent tyre guage - had cheapass SCA one, but it died)
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
