Hey tanehy do you know what software your car is running? I am due to pick up my 125TSI mid April and planing on having the APR remap too. Is your Tig a Jan 2010 built date? could this be the problem?
Just a question in regards to the APR remaps, if you take your car to have a service at VW, could it be possible that VW might release a new official ECU reflash? If so would it over ride an existing APR map? and would APR allow unlimited reinstall of their product.
No idea which version my car is running... there was a whole string of numbers that Dean showed me but it was the last 4 numbers which were the problem apparently.
My car is a Oct 2009 build.
Well I have the track and field version and I had the option to buy a BSH one from the US built for the GTi as I'm a dealer of them, but it didn't fit correctly so I needed to make some different tubes and change a bit the bracket.
But it's perfect and it's waaaaay faster and consistent under this +30°c temperatures.
11/08 build and they haven't updated mine yet - at least nothing that has effect the APR mapping (but then my delaer knows what I have loaded too).
AWE Turbo outlet pipe.
http://forums.vwvortex.com/zerothread?id=4825546
Not sure if it will work on our Aus delivered 4Motion tiguan's though.
Is this the same as a downpipe?
They're almost identical to the Neuspeed items so they should fit fine on the 4mo tig (according to Neuspeed their's fit on the 4mo).
http://www.neuspeed.com/products/pro...<ype=ns_euro
Forever blowing bubbles.
