Page 32 of 33 FirstFirst ... 2230313233 LastLast
Results 311 to 320 of 327
Thread: Tuning / performance update
  1. #311
    Feb 2010
    Quote Originally Posted by tanehy View Post
    Got my 125TSI yesterday and had it booked in with Volkspower in Burwood, Victoria this morning to get the APR ECU remap. Unfortunately was told that the version of the software on my car was incompatible with their system and needs some tinkering and the entire programme needs to be downloaded and sent offshore to be reworked may take 1-2 weeks.
    Hope others don't have the same problem. Dean at Volkspower was really great about it though and offered a loan car to me whilst they keep my car for the 3 hours they need to download the software.
    Still dreaming of 190kw......
    Hey tanehy do you know what software your car is running? I am due to pick up my 125TSI mid April and planing on having the APR remap too. Is your Tig a Jan 2010 built date? could this be the problem?
    Just a question in regards to the APR remaps, if you take your car to have a service at VW, could it be possible that VW might release a new official ECU reflash? If so would it over ride an existing APR map? and would APR allow unlimited reinstall of their product.
  2. #312
    Jun 2009
    Quote Originally Posted by phamda View Post
    Once you have purchased the remap, you can have it re-flashed onto your ecu if Vw wipe it for no charge according to APR.
  3. #313
    Mar 2010
    Soutbank, Victoria
    No idea which version my car is running... there was a whole string of numbers that Dean showed me but it was the last 4 numbers which were the problem apparently.
    My car is a Oct 2009 build.
  4. #314
    Mar 2009
    Guatemala Central America
    Which intercooler did you use for the upgrade ?
    S3 intercooler is 30% larger than the std Tiguan's and can easily be fitted.
    APR intercooler is almost 100% larger, but costs more ...
    and BTW, once the APR dowpipes are approved for production, I believe they will be distrubuted from Australia to all markets that need them ....
    Well I have the track and field version and I had the option to buy a BSH one from the US built for the GTi as I'm a dealer of them, but it didn't fit correctly so I needed to make some different tubes and change a bit the bracket.
    But it's perfect and it's waaaaay faster and consistent under this +30°c temperatures.
  5. #315
    We have at least 9 separate files for the petrol Tiguans so far, and VW are releasing new versions every batch (or so it seems).
    We are trying to keep on top of it, but until we see it, we can't capture it
  6. #316
    Edit - just checked - 16 different software variants (factory)
  7. #317
    Jul 2009
    Singapoe, Singapore
    yes.. it's actually common to see the different variants.. most of the time, there are little tweaks that they make to the engine management system.
    the major changes usually come 2 years from the time that model was first launched....
  8. #318
    Nov 2008
    QLD
    11/08 build and they haven't updated mine yet - at least nothing that has effect the APR mapping (but then my delaer knows what I have loaded too).
  9. #319
    Jun 2009
    AWE Turbo outlet pipe.
    http://forums.vwvortex.com/zerothread?id=4825546
    Not sure if it will work on our Aus delivered 4Motion tiguan's though.
    Is this the same as a downpipe?
  10. #320
    Jul 2007
    Canberra
    They're almost identical to the Neuspeed items so they should fit fine on the 4mo tig (according to Neuspeed their's fit on the 4mo).
    http://www.neuspeed.com/products/pro...&ltype=ns_euro
    Forever blowing bubbles.
