Simon, as we know, dyno's inheritanlty give quite large variations in readings depending on a whole range of influences and circumstances at the time. So be great if you could set it back to stock map, do a run, then straight away switch up to performance map and compare the differences. That will give really good indication of what's happening.
- You may not post replies
- You may not edit your posts
Forum Rules
