Originally Posted by
clip
[/I]That implies a loss through the transmission of between 5.3-11%. Even the best automatic transmissions with lock-up TCs achieve between 80-85% efficiencies.[/I]
This indicates auto transmission losses are 6-15% higher than manuals.
This doesn't pass the common sense test. If average power usage during normal driving is 30kW, then the auto is losing an extra 3kW over a manual. That's a lot of heat dissipated, even with a transmission cooler. Worked hard, putting out av 100kW (eg towing up Adelaide Hills), you'd be looking at 10kW, which would fry an egg on your console.
TDI tiguan in the drive. ParkAssist, comfort, fogs
Service every 15,000, new fault code every 7,500km
