Has anyone got a rough idea of the power output at the wheels with the APR remap? Thinking of getting a dyno run done and want to know what sort of front wheel kws I should be getting :D
Printable View
Thanks Johan, will report back when I get her done :) Apparently there's a plug I need to pull out on the rear diff so it's only fwd? Will ask Guy just to make sure, don't want it to launch off the dyno! :emo_baghead:
Simon, as we know, dyno's inheritanlty give quite large variations in readings depending on a whole range of influences and circumstances at the time. So be great if you could set it back to stock map, do a run, then straight away switch up to performance map and compare the differences. That will give really good indication of what's happening.
Probably a good reason not too?, but wouldn't it be cheaper just to change the final drive ratio. Not sure if a 10% increase would get both 60 in first and 100 in second, but would go close and only push 6th out to 55klm/hr/1000rpm, no more than the Diesel Tig, upgraded torque would easily handle that.
Gathered you've considered? Anyway if 1st and 2nd got longer legs, longer legs right thru the gears could make good sense, so a change in diff ratio would seem to have some merit and I presume much cheaper? main question perhaps is just how much increase is needed, too much and diff is probably out, if that is, not for other ......:brutal:
not for me jim, sixth is already too tall for our low speed limits IMO. TBH, I rarley run in 6th unless it's on the flat in 110k zone (like Suny Coast to Bris). I got better economy driving down the New England Hwy from Toowoomba to Sydney using 5th most of the time travelling at the speed limit, than I did using 6th on the same trip 2 months later (I wanted to test the point myself).
3rd, 4th and 5th gears are awesome, perfect ratios IMO. But I'd love a taller 1st with a well matched 2nd to follow up.
Not sure how you could change final drive ratio, wouldn't that involve changing both front and rear diffs?
Clip yes I was thinking about it after I posted yesterday and as a 4wd probably means changing both front and rear diffs, so may not be that much of a saving in the end.
Anyway we all agree a taller 1st and 2nd would be good, variations in opinion on the other gears.
Interesting re fuel economy in 5th versus 6th. Cant say I've ever tested that, but from what I have seen on the MFD occassionally, sixth seems more economical at hwy speeds and should be. Your diff in fuel economy on the new england could be due to a range of factors - headwinds, direction (more uphill one way than the other), use of air con etc.
I'm in sixth regularly from 80-90, though it pulls cleanly from 75. Even at a 100, its virtually unstoppable in 6th (re hills), and plenty of go for most overtaking situations.
has anyone seen any specs for tiguan speed in gears or klm/1000 rpm for the Manual TSIs?
Having taken her for a blast last night:P, I am wondering now whether the gearing is even lower than I thought, especially in first and 2nd:frown:. I've searched the web a bit and called APR and cant find any such data. Best were some US specs for ratios, but without calculating tyre circumference etc still doesn't give you the figs and US spec may be slightly different anyway.
Secondly anyone tested/have any views on whether its worth taking the engine beyond 6000rpm, have wound it out a number of times, but not quite convinced the last 500 or so rpm are worth it (ie that upchanging at 6000rpm may give a better result than taking all the way to the redline).
SHARKIE - you do any acceleration fig testing yet?
