Page 13 of 33 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 327
Thread: Tuning / performance update
  1. #121
    Jul 2007
    Canberra
    Thanks Guy but I'm not a member there, can't view them. Does this intake use a pod or panel filter?
    Forever blowing bubbles.
  2. #122
    Uses a pod but fully enclosed in a carbon fiber enclosure.
    Will get it up on our website in the next couple of days.
  3. #123
    Nov 2008
    QLD
    dyno chart would be great to see if there's any top end improvement.
  4. #124
    "Cold air induction is accomplished by completely sealing the intake system from the hot engine bay air and then taking it even further through the choice of Carbon Fiber material and an additional thermal barrier application to the inside of the intake system. Quite often intakes are advertised as cold air induction even though the material choice is a metal or plastic composite which simply does not insulate the incoming air from the hot engine bay air or does not completely seal the intake system in the engine bay allowing hot air to enter the intake stream negating any cold air induction gains."
    14 ftlb & 16hp - test car had a full exhaust but it is a good test! 93 MON octane = 98 RON octane
  5. #125
    Jul 2007
    Canberra
    Is the filter a re-usable oil jobbie or a dry filter Guy?
  6. #126
    Nov 2007
    Quote Originally Posted by Pullstarter View Post
    Looks like a reusable oil 1.
    BTW that 16hp is 11kw, but that might be dependant on having an exhaust done already.
    So I figure anywhere between 5-11kw on its own .....
    So .... APR ECU, Carbonio intake & exhaust = about 210kw on the TSI ......
  7. #127
    Jul 2007
    Canberra
    APR is going to send me broke!!! Damn their goodness!!
  8. #128
    Wash & re-use filter
  9. #129
    Jul 2007
    Canberra
    Here are some pics of a stock TSI airbox and a pod located in its place.
    Note in particular the curve of the feed to the airbox and the high position for the mount for it when fitted. This is what could potentially be the problem with the CAIs currently out there as I suspect the TSI Golfs are different. We will need to fit 1 to see if it works. Who's game to be the "crash test dummy"?
    Johan, do you have any info on the size of the silicone elbow they used there? I just did some measurements and the stock intake OD is 80mm. I'm looking at using one of these which has a 70mm mounting OD;
    http://www.knfilters.com/universal/apollo.htm
    Would need that elbow in the pics I think, looks to be a reducer elbow.
  10. #130
    Sep 2009
    Perth
    check this video out, DIY chip install for TDI, appears to be a hardware chip that can be easily install or remove at any time.
    http://www.youtube.com/watch?v=yiHRjwZmAO8
