Results 1 to 4 of 4
Thread: Trickle charger
    Jun 2009
    Murchison,Victoria
    Trickle charger
    hey folks,
    i for years have had trickle chargers on my motorcycles and i leave my tig for up to 4-5 days at a time, Im wondering can you use any of the 12v outlets to place a trickle charger on, or does the computer think some strange thing is happening?
    Also on that point of Flat batteries, as the tig has no key entry how do you get into a locked car with a flat battery??
    regards
    Phil
    Dec 2008
    Alexandra, New Zealand
    Quote Originally Posted by ploz58 View Post
    regards
    Phil
    You're about the 10th person I've seen make that mistake. I could just be rude and say "if all else fails read the instructions" but cos it's Friday I'll take it easy on you:
    There IS a key hole BUT it's covered with a little clip on cover at the end of the door handle. Open the cover and use the key OK
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Adelaide hills, SA
    hey folks,
    regards
    Phil
    And as for the trickle charger I would recommend CTEK, it comes with the connector that you can connect to the battery and you can just plug the connector from CTEK to charge and maintain your battery.
    http://www.mediafire.com/file/0idnez...EK Charger.zip
    Jun 2009
    Murchison,Victoria
    key
    Thanks Derek,
    after i wrote that i thought its probably in the owners manual,
    i appreciate you being gentle,
    regards
    Phil
