Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: Trailer hitch for carrying bicycles
    Dec 2010
    Tiguan - Aftermarket hitch
    Any able to buy an aftermarket hitch for their Tiguan. I don't need a full on tow bar, just a hitch and bike rack to carry a few bikes.
    $87 plus delivery from USA sounds like quite a cheaper alternative then getting a full towbar. Installation seems to be a breeze although it does require cutting into the bumper.
    Trailer Hitch by Hidden Hitch for - 87600
    Tiguan My11 125TSI DSG
    Buyii - Daily Deals all on one page
    Dec 2010
    newbie question here. whats the difference between that hitch I linked in the first post, and this one on eBay that seems to be larger and have a bigger mount/arm? Guessing it has a higher load capacity?
    09-10 VOLKSWAGON TIGUAN TRAILER HITCH CURT CL3 13058 | eBay
    Mar 2011
    Sunshine Coast
    It looks like good value, although freight would be high. I don't know enough about towbars though, and have noticed a lot of comment on the forum about the issue you might read. I also wonder if the transport department or insurance has something to say on the type of accessory used.
    Dec 2008
    Alexandra, New Zealand
    The NA's just cut out a bit of plastic and then bolt into already threaded holes in the steel bumper beneath, you need to be certain those fittings even exist on your Ausi Tig !!!
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Nov 2007
    Quote Originally Posted by zhenjie View Post
    Quote Originally Posted by NZTiguan View Post
    I tried that, purchased just the hitch (VW OEM North America) from the USA and tried to fit it ...... Turns out the Australian delivered Tiguans do NOT have the threaded holes in the steel bumper underneath ...... I still have the hitch in my garage if you'd like to try ..... be even cheaper than that including postage as to me its just an expensive paperweight at the moment .....
    Dec 2008
    I'm pretty sure that's why the Americans have a 2000LB tow limit rather than 2000KG, their hitch is just "tacked on".
    Derek
    Alexandra
    Dec 2010
    oh bugger! so our cheapest option for just a hitch would be to go for the full tow bar ?
    thanks guys thats why i love this forum, save me cutting my bumper.
    Dec 2008
    Yep, and at least you know it will take a decent load if required. If you're just carrying bikes or something you could always leave the electrics till later.
    Derek
    Alexandra
    Jan 2011
    Hi all,
    Just FYI, I've been having an explore of the various options for Towbars etc. and after checking out my Towing Eye Attachment Point (there is one Front & supposed to be rear - behind the small access panels in the bumpers) and I discovered that I don't HAVE the Tow Eye Attachment point at the back - the access panel just opens onto black, square section tube. After chatting to my dealer about it, it seems that it is a part of a Towbar Package, but not one we can get the rest of here. That's another story, however, and I digress...
    So today, due to a mild case of OCD and wondering what else is behind the rear bumper, I cut out the pre-scored panel on the underside of the bumper. Lo and behold, it's definitely part of a Towbar (even has a bracket for the electric Socket to be attached to) and the 4 holes needed to attach the Hitch as mentioned above are there!
    Mine is a 2011 Tig, so Zhenjie, I'd suggest cutting that panel out as I mentioned above, and I dare say you'll find the 4 holes to bolt your hitch straight onto. You can't see the cut-out hole once it's done unless you get on your hands & knees, and there's nothing that's going to suffer from cutting it out - no wiring or anything. Good luck!
    MY2011 Tiguan 103 TDi 7spd-DSG, Deep Black Pearl Effect, Comfy Pack, MDi, OEM Tow Package, Tint - LOVE this car!
    Jan 2011
    Hi all,
    Oh and obviously, if you intended to actually TOW anything rather than just mount a Bike Carrier (remember to torque the 4 bolts in), I'd get it checked out thoroughly - apart from needing the Electrics sorted, the brackets at the side of the bar (going forward) are impossible to see, so no telling what they're attached to (I assume they're solidly done, but you know what happens when I assume - I make an ASS out of U & ME...well, mostly me, really!). Worth investigating though!
