Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Towing - Tiguan tow capability
  1. #21
    Dec 2008
    Alexandra, New Zealand
    LED lights do not create enough resistance in the circuit and so throw up faults. You need to install resistors in the lines so that the all-up resistance is the same as normal bulbs.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
  2. #22
    Jun 2009
    Murchison,Victoria
    Trailer lights
    Well tonight i put my boat trailer on the tig, it has incandescent globes.
    the worked fine except the taillights which i knew about,
    The MFD promptly told me, trailer left tail light not working and then tralier right lail light not working!!!!
    So it appears i have to do something with my motorcycle trailer with the LED lights.
    any suggestions?
    thanks in advance
    Phil.
  3. #23
    Nov 2008
    QLD
    Quote Originally Posted by ploz58 View Post
    any suggestions?
    thanks in advance Phil.
    this might explain how they work:
    http://forums.xbox-scene.com/index.php?showtopic=522781
    then this might help with your calculations:http://metku.net/index.html?sect=vie...calc/index_eng
  4. #24
    Dec 2008
    any suggestions?
    thanks in advance
    Phil.
    When I got mine in NZ it threw up faults left and right as well. I found that the Tig is wired for "separate" left and right taillights while the trailer was wired in common. I had to run an extra wire to separate the taillights and then ensure that the connector plugs matched. The dealer had put the two taillights into the one connector as is standard on NZ connectors so I just separated them and used one of the spares to run the second circuit. Not nearly as difficult as it sounds, only took me about 20 minutes all up and I'm no auto-electrician.
    Derek
    Alexandra
  5. #25
    Nov 2008
    QLD
    the worked fine... So it appears i have to do something with my motorcycle trailer with the LED lights.
    any suggestions?
    well, you could just ditch the LEDs and put a set of incandescent tail lights on - pretty simple rather than going to all that other trouble.
  6. #26
    Jun 2009
    Murchison,Victoria
    towing capabilities
    Hey clip
    I liked your simplistic answer,
    but i would still have this issue of left and right tail light globes.
    Can this be disabled as i cant imagine any trailers in aus are wired that way.
    The connector that goes into the car into has a large number of pins in it, Are they all meant for something, yet the other end only has a 7 pin plug.
    In someways a modern car you would think we be more set up for LED type lights and not the old technology
    i have some resistors i purchased for the led lnidicators on one of our dirt bikes
    ill put them in the lines and see what happens.
    Given i have 4 different trailers the tig will need to tow this could be a pain, and they are a mix of led and incandescent globes
    i passed a tourag towing a caravan , it had LED lights on it, i felt like asking him if had any dramas or had made conversions
    thanks for the advise out there
    Phil
  7. #27
    Nov 2008
    QLD
    Phil, just whack in the resistors, pretty sure that will fix it for you - just a pain to do that's all.
  8. #28
    Mar 2009
    Latest from Hayman Reece re: aftermarket Towbar:
    Apologies for the further delay in this towbar, where we are at is that the Tiguan has a complicated wiring system, for the trailer lights to operate correctly we need to add a special Trailer Control Module (TCM).
    In the past motor vehicle manufacturers have sold this TCM as a separate item, but in typical Motor Vehicle company fashion, most of them are now not selling this item separately, they only sell them as part of a Towbar kit. From the research our sales team have done, the Tiguan is one of the vehicles that this is happening to. To ensure we can sell our Tiguan towbars, and other complicated electrical system vehicles, we have had to engage the services of an electrical engineer to develop an aftermarket TCM that we can sell with our towbar.
    For this reason we have decided to hold off the sale of these towbars until the wiring solution is complete. I know in your case you don’t need the wiring, but our sales and management have decided that this is the way they are going to deal with this vehicle in particular.
    I do have your details, along with about 20 others, in my file and as soon as I have an exact date for release I will advise all concerned.
    Again I apologize for any inconvenience this is causing, but as the market leaders in towing accessories we want to make sure we get it right the first time.
    TDI tiguan in the drive. ParkAssist, comfort, fogs
    Service every 15,000, new fault code every 7,500km
  9. #29
    Tow it right Keep it light
    One of the big reasons for looking at Tigs for me was that I have an Avan Aliner ( a small camper van Tow mass 780 + contents , ball weight 70kg). Currently towing it with a Honda Accord 4cyl. Accord is acceptible but the increased height, road weight and economy are the reasons Tiguan came into my line of sight.
    Since then everything else about the Tiguan, be it the safety, the look, the price and the reliability are the things that have wowed me. I have not towed with a Tiguan yet, but compared to what I am already using I know this car matches my needs.There are some really good small vans out there to meet the requirements of tow ball weight and towing mass. But if you want a bigger van, buy a bigger tow vehicle.
  10. #30
    Apr 2010
    Cairns
    Hi All,
    I bought a new "wild cherry red" tiguan three days ago..with a dealer fitted towbar, with intentions of purchasing a small pop top camper for family camping holidays. Upon investigating towing i became aware of towball download limits and it seems i cant tow a pop top camper as the down load limit will be about 130KG with the camper loaded? I discussed this with a camper dealer who seemed to think the 100KG limit is wrong or misleading as the GVM including passengers and lugage is a factor also? Camperguy's take on it was the GVM + 100KG was the load limit on the rear of the tig?? So in theory... if weight in car or GVM is less than stated then extra load can be applied to towbar?? Can somebody please enlighten me.. I feel like im being sold a camper i wont be able to tow.. even though the explanation makes sense??!
    Shiny new red tig with RCD 510,MDI,fiscon kufatec, comfort & a useless towball
