Originally Posted by
pinzvidz
Doesn't it come down to how the manufacturer of the camper or caravan has set up the weight distribution, axle positioning and so forth? Some might indicate a tow ball weight of only about 65kg or so, others might indicate 100kg, for a similar size camper or van.
The standard setup for caravans in Australia is usually a ball weight of 10% of total weight. I hope you NEVER get to tow anything loaded with extra weight to the rear (or move the axle line) to achieve a light ball loading. Unfortunately I have.
People forget that the towed item swivels about the TOW BALL not around the axle. Weight behind the axle (to lighten the ball weight) has a greater moment arm than weight in front of the axle, and that rear weight makes it sway like crazy if overdone. As the weight of a caravan or trailer increases, a greater proportion (10%) needs to be in front of the axle to contol sway tendencies and hence increases ball weight.
Granite Passat sedan TDI (125kw), DSG, beige leather
Candy White Polo 6R, 66TDI, DSG, no options
