Originally Posted by
wongai
Hi All,
I bought a new "wild cherry red" tiguan three days ago..with a dealer fitted towbar, with intentions of purchasing a small pop top camper for family camping holidays. Upon investigating towing i became aware of towball download limits and it seems i cant tow a pop top camper as the down load limit will be about 130KG with the camper loaded? I discussed this with a camper dealer who seemed to think the 100KG limit is wrong or misleading as the GVM including passengers and lugage is a factor also? Camperguy's take on it was the GVM + 100KG was the load limit on the rear of the tig?? So in theory... if weight in car or GVM is less than stated then extra load can be applied to towbar?? Can somebody please enlighten me.. I feel like im being sold a camper i wont be able to tow.. even though the explanation makes sense??!
Shiny new red tig with RCD 510,MDI,fiscon kufatec, comfort & a useless towball
A few facts about towing from a caravaner.
A The weight on the towball is part of the payload of the tug and is included in the GVM of it. There is no statue about towball weight and you must adhere to the manufacturers specifications
B Fitting a WDH does NOT lighten the ballweight as the ballweight is measured disconnected from the car and is ALWAYS that weight
It does distribute a small portion of that weight onto the cars front axle and the van axle by the fact of it straightening the joint between car and van.
C you must also consider the GCVM or the combined weight of both vehicles and it should not be exceeded.
D A trailer(van) of over 750KG loaded weight must have brakes which may be either over ride or electric. If electric you must have a controller in the car accessible to the driver. Heavier vans have different requirements but as a Tig cant tow them we wont discuss them.
Also the rules say you can tow either the allowable weight set by the manufacturer or the amount set by the towbar maker, WHICHEVER IS THE LESSER. So if you have a 1500kg limit by VW and a 1250KG towbar you can only tow 1250kg Like wise if car is 1500kg and you have a 2000kg towbar its only 1500kg limit
