Results 1 to 10 of 45
Thread: Towing - Tiguan tow capability
    Frankston Victoria
    I am pretty much looking forward to seeing the Tiguan. On the face of the specs and viewing photos on the internet it looks like it will be a fantastic vehicle; well suited to touring and occasional towing a camper trailer or small poptop caravan.
    I note in a number of reviews that the towing capacity is somewhere around two tonnes depending on model - I would think well within the capability of the diesel option. Volkswagen are reported to claim that this is class leading.
    I understand that the towball mass rating (downward load on the towball) is most likely to be set at 100kgs for Australia. Most camper trailers and small poptops will impose a greater load than this, and as such ruling out all but the very lightest of RV trailers. The general rule of thumb is that the tow ball loading is 10% of the trailer weight.
    I would like to see the Tiguan being able to tow an RV trailer of about 1300 kgs. I would love to hear of a way around this (apart from buying a tent).
    Feb 2007
    SE QLD
    Doesn't it come down to how the manufacturer of the camper or caravan has set up the weight distribution, axle positioning and so forth? Some might indicate a tow ball weight of only about 65kg or so, others might indicate 100kg, for a similar size camper or van.
    Feb 2008
    Townsville QLD
    Quote Originally Posted by pinzvidz View Post
    The standard setup for caravans in Australia is usually a ball weight of 10% of total weight. I hope you NEVER get to tow anything loaded with extra weight to the rear (or move the axle line) to achieve a light ball loading. Unfortunately I have.
    People forget that the towed item swivels about the TOW BALL not around the axle. Weight behind the axle (to lighten the ball weight) has a greater moment arm than weight in front of the axle, and that rear weight makes it sway like crazy if overdone. As the weight of a caravan or trailer increases, a greater proportion (10%) needs to be in front of the axle to contol sway tendencies and hence increases ball weight.
    Granite Passat sedan TDI (125kw), DSG, beige leather
    Candy White Polo 6R, 66TDI, DSG, no options
    Jan 2009
    SEQ
    Quote Originally Posted by Maltreck View Post
    ...well suited to touring and occasional towing a camper trailer or small poptop caravan.
    I hear you.
    Reading the specs for Tig on the VWA site Max (braked) towing is 2000Kg's. Unbraked is 750 which (just enough for a BASIC box trailer).
    Towball rating it 100Kg. So we are really limited to 1000Kg trailers if we want to drive with and comfort for any distance etc.
    Do you know how much VWA charge for this 'pleasure' (the tow ball option)?
    Jan 2009
    SEQ
    WOW!
    I found this thread over at MyTiguan.com
    http://www.mytiguan.com/viewtopic.php?f=44&t=5667
    Dec 2008
    Alexandra, New Zealand
    Quote Originally Posted by TonyTA View Post
    I don't think this is necessarily correct (that trailers always have 10% of their weight as tongue weight). I tow a 14 foot conventional caravan that I'm sure would be well over 1000kg and I can lift the towbar onto the towball, I'm pretty certain it's less than 100kg. If it was correct a 2000kg caravan would have a 200kg drawbar weight and there's not a chance I could lift that by myself !!
    I also saw somewhere that caravan tests in Britain are down with a towball loading of 80kg (they evidently load them specifically to achieve this). I agree that you don't want the towball load too light BUT as long as the main load is on the wheels and not behind them I don't think this is an issue.
    Also if you go to a much heavier trailer with tandem wheels the tow bar loading is less from what I've experienced. I have the feeling that a lightweight box trailer or similar may have a 10% tongue load when EMPTY but that when you load it you wouldn't necessarily then add 10% of the load weight to the drawbar end ?
    Not true ?? perhaps somebody could show us some examples that do have total weights of around 2000kg AND towbar weights over 100kg ??
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Ipswich Qld
    Would the use of a weight distribution hitch work on the tiguan, to lower the ball weight?
    Jun 2009
    Murchison,Victoria
    Angry tow bar questions
    hey folks,
    i might be in the wrong spot here,
    when purchasing my tiguan TDI, i had to juggle the finances a bit.
    So when asking about the genuine towbar was told , $1250.00 fitted,
    Now i thought id get it fitted, during my 3k service i am told, $1250 for the tow bar and $700.00 to fit it!!!!
    Has anyone else had this happen and are there alternatives, i understand there is a black box that has to be included.
    Little saddened by dealer, sales saying one thing then service saying something else.
    Be interested in an alternative just in preference to being done by the dealer
    Phil.
    Dec 2008
    Sydney/Canberra
    $700 does seem a bit steep. It sounds like they're charging you the same as they would for the early Tiguans that weren't pre-wired for the trailer control module wiring.
    If it is infact pre-wired, (the saleman will have an invoice from VW with the words "Preparation for towing" on it), then it is little more than a few hours work to have the towbar fitted, and wired up. I would suggest you ask them to re-assess your quote. Better yet, shop around with a few other dealers.
    Jul 2015
    Sydney NSW
    Consider a euro van (eg Swift or Geist) designed to be towed by euro cars instead of the nose heavy local/american designs designed to be towed by monster trucks. My 6.4m Geist built Hobby weighs 1640kg, has a ball weight limit of 100kg. You must be pedantic about loading over the axles to avoid speed sway. I cruise between 80-90km/h as well.
    Sent from my SM-N915G using Tapatalk
    130kw TDi
